Rendering modes
Command
Path
[Render mode]
View > Rendering
The render modes translate the drawing in various ways to create an image with realistic details and effects. For example, a hidden line rendering is similar to the non-rendered (wireframe) image, but it hides the portion of the objects that would not normally be visible. A Shaded mode rendering also has hidden lines, and colors and shading; it shows how the light sources interact with the object surfaces, and it can show any textures that were applied.
The View bar provides quick access to the rendering commands, and to render styles, on the Current Render Mode menu. The Current Render Mode Options icon changes to reflect the current render mode, and opens the options dialog box for the render mode, if applicable. If the current render mode is a render style, a small arrow displays on the icon.
The Current Render Mode Options button and the Current Render Mode menu on the View bar
The rendering speed depends on the rendering option selected and the number and complexity of objects in the file. Shaded, Renderworks, and Realistic RS render modes/styles do not all display the same lighting and texture features, and models that use different effects will display differently in each render mode; you may need to view your model in different render modes to achieve the desired effect for a specific model.
Once the drawing is complete or near completion, any textures have been applied, and any desired lighting has been added, select one of the standard views (see Using standard views), and use Onscreen View Control and the Flyover, Walkthrough, Translate View, or Rotate View tools to orient the drawing. For presentation purposes, it is often easier to create sheet layer viewports and render the sheet layers, or render a selected area; both sheet layer viewports and render bitmaps can render in the background while drawing processes can continue.
You can continue to work in an active design layer while it renders. Changes to the drawing automatically cancel the rendering in process and begin it again with the changes incorporated. An animated icon in the center bottom and progress bar at the bottom right of the drawing window indicate that rendering is queued or is in progress.
Save files in wireframe mode rather than in a rendered mode, so that files draw more quickly when opened. Rendered viewports are saved in a rendered state when Save viewport cache is selected in the Display tab of document preferences.
For smoother rendering of mesh objects, enable mesh smoothing for the entire file in the document preferences (see Document preferences: Display tab) or for selected meshes on the Render tab of the Object Info palette (see Managing object textures from the Object Info palette).
To select a render mode:
Select the command, and then select the desired render mode, or select the render mode from the Current Render Mode menu on the View bar.
To cancel a rendering before it is complete, press the Esc key.
Rendering command
Shortcut
Description
Wireframe
Ctrl+Shift+W (Windows)
Cmd+Shift+W (Mac)
A visual representation of the model is created using lines to represent object edges; see Wireframe options to adjust settings for planar objects
Shaded
Ctrl+Shift+G (Windows)
Cmd+Shift+G (Mac)
Creates a good-quality, detailed rendering, with colors, shading, and textures; see Shaded options for details
Fast Renderworks
Renders without anti-aliasing or ray tracing; low detail level
Final Quality Renderworks
Ctrl+Shift+F (Windows)
Cmd+Shift+F (Mac)
Renders with reflections, shadows, anti-aliasing, transparency, and a high level of detail
Custom Renderworks
Renders with parameters set by the user; see Custom Renderworks options for details
Artistic Renderworks
Renders with multiple sketch styles for a hand-drawn look; see Artistic Renderworks options for details
Hidden Line
Ctrl+Shift+E (Windows)
Cmd+Shift+E (Mac)
Hides the edge lines of objects that are behind other objects, which gives a solid appearance; optionally displays surface hatches that give the appearance of textures (see Line render options and Hidden line rendering with surface hatches)
Dashed Hidden Line
Ctrl+Shift+D (Windows)
Cmd+Shift+D (Mac)
Edge lines of objects that are behind other objects display as dashed lines; see Line render options to set the appearance of the lines
Sketch
(Design Suite product required)
See Sketch rendering.
Unshaded Polygon
Displays objects as solids, and displays attributes such as colors
Shaded Polygon
An Unshaded Polygon rendering with shading added
Shaded Polygon No Lines
A Shaded Polygon rendering with no edge lines
Final Shaded Polygon
Ctrl+Shift+P (Windows)
Cmd+Shift+P (Mac)
A Hidden Line rendering on top of a Shaded Polygon - No Lines rendering; edges and curved surfaces are cleaner than those in a Shaded Polygon rendering. See Line render options to set the appearance of the lines.
There are a few additional render modes that are not available as commands.
Realistic RS is an additional photorealistic render mode that is available only as part of a render style; see Render styles.
Showcase (Spotlight required) is a previsualization render mode based on Shaded mode that is available when creating sheet layer viewports or exporting path animations; see Concept: Showcase. Showcase render mode is also available for use as a render style.
To get the best performance from rendering, use a video card that supports hardware-accelerated render modes. There are significant compatibility issues with some cards; see vectorworks.net/sysreq for a list of video cards that are compatible with the Vectorworks program. If a model is too complex to render the design layer successfully, an alert message displays, informing you that the render mode has been switched to wireframe.
The power-saving video settings of some laptops may cause out-of-memory issues or other display issues that can easily be solved by turning off the power-saving video features.
A Vectorworks preference sets the preferred 3D render mode, applied whenever the drawing is switched from Top/Plan into a 3D view; see Vectorworks preferences: 3D pane.
Wireframe options
Shaded options
Line render options
